Prashantdogra
Aug 30, 2016Aspirant
Wireless working but not wired model :c3000
Hi,    My 'netgear N300 wifi cable modem router' is working for wiresless but the ethernet suddenly stopped working. I have two ethernet ports on modem/router and tried both of them. None works. The e...
Prashantdogra
Sep 01, 2016Aspirant
Thanks Darren. I checked ethernet cords.. Tried with new ones as well. I dont think thats an issue. Do you know how to do factory reset? I tried switching off, taking wires off, holding for dew mins and then conencting again.
DarrenM
Sep 01, 2016Sr. NETGEAR Moderator
Hello Prashantfogra
You will have to hold down the reset button for 10 seconds which is a pinhole on the back of the modem that will factory reset the modem.
DarrenM
