Prashantdogra
Aug 30, 2016Aspirant
Wireless working but not wired model :c3000
Hi,    My 'netgear N300 wifi cable modem router' is working for wiresless but the ethernet suddenly stopped working. I have two ethernet ports on modem/router and tried both of them. None works. The e...
Prashantdogra
Sep 22, 2016Aspirant
Please let me know if you get a fix. This is very bad thing. They wont help fixing this and looks like it happens quite often with lot of users.
DarrenM
Sep 23, 2016Sr. NETGEAR Moderator
I suggest contacting support at this point if the ports are still not working after a factory reset and the modem is still under warranty.
http://www.netgear.com/support/contact.aspx?cid=wmt_netgear_organic
DarrenM
