Isner79
Aug 14, 2020Aspirant
wireless works, wired does not Nighthawk AC1900, C7000 modem/router
I have an interesting scenerio, or at least I think I do. I got home from work today thinking my internet was out because my Desktop PC, smart TV and Alarm system (all wired connnections) were repor...
Aug 17, 2020Guru - Experienced User
Is the modems web page using a wired PC and web browser accessible. If it's accessible, does the Basic tab page report any INTERNET connection issues?
Have the ISP check the signal and line quality UP to the modem.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute them back ON.
- Isner79Aug 25, 2020Aspirant
there is no issue with my internet connection what so ever, it's working perfectly fine, the issue is all 4 ethernet ports on the back of the modem stoped working. the wifi connections still work just fine but for my PC I need the ethernet ports because wifi isnt fast enough for my job
- FURRYe38Aug 25, 2020Guru - Experienced User
I presume you have done a factory reset on the modem?
I would make contact with NG support and ask what yoru options are.
done a couple factory resets and my only option when it comes to Netgear support is to pay them so I can ask a question, my warranty expired almost 3 years ago.
Thats why I came here, I was hoping someone here would know how to get my wired connections working again.
I may as well just get a new modem/router at this point because it costs damn near that much to 'buy' support after your warranty is expired.
Thanks anyway.
