Isner79
Aug 14, 2020Aspirant
wireless works, wired does not Nighthawk AC1900, C7000 modem/router
I have an interesting scenerio, or at least I think I do. I got home from work today thinking my internet was out because my Desktop PC, smart TV and Alarm system (all wired connnections) were repor...
Isner79
Aug 25, 2020Aspirant
there is no issue with my internet connection what so ever, it's working perfectly fine, the issue is all 4 ethernet ports on the back of the modem stoped working. the wifi connections still work just fine but for my PC I need the ethernet ports because wifi isnt fast enough for my job
Aug 25, 2020Guru - Experienced User
I presume you have done a factory reset on the modem?
I would make contact with NG support and ask what yoru options are.
- Isner79Aug 25, 2020Aspirant
done a couple factory resets and my only option when it comes to Netgear support is to pay them so I can ask a question, my warranty expired almost 3 years ago.
Thats why I came here, I was hoping someone here would know how to get my wired connections working again.
I may as well just get a new modem/router at this point because it costs damn near that much to 'buy' support after your warranty is expired.
Thanks anyway.
- antinodeAug 25, 2020Guru
> [...] all 4 ethernet ports on the back of the modem stoped working.
> [...]Sounds like hardware, but more testing should be possible.
Does the C7000 have informative LED indicators on those Ethernet
connectors? (The picture in the User Manual is suggestive, but the text
seemed not to be.)If you connect a computer to one of them (using a known-good cable),
then what does the OS tell you about the state of that physical link?If everyone agrees that the ports are dead, then a new gizmo (or two)
would seem to be the next step.
