gshinks
Jun 02, 2019Follower
WNDR4300V2 - No internet or service access when connected to cable modem
I've been using a N750 router with a Motorola SurfBoard cable modem and Comcast internet service for several years. No changes have been made to my network, but yesterday I noticed all of our wifi d...
Jun 03, 2019Guru - Experienced User
Please post about this here for your model router:
https://community.netgear.com/t5/General-WiFi-Routers-Non/bd-p/home-wifi-routers-general
Good Luck.
gshinks wrote:I've been using a N750 router with a Motorola SurfBoard cable modem and Comcast internet service for several years. No changes have been made to my network, but yesterday I noticed all of our wifi devices were no longer connected, nor were any wire-connected devices. Here is a summary of all the things I have tried and/or discovered:
- All physical connections are fine
- All indicator lights are normal
- The router firmware is up-to-date (1.0.0.58)
- A factory reset and power-cycling of all hardware changed nothing
- When the cable modem is disconnected from the router, the router works as expected (i.e. I can access the configuration utility through a browser, WiFi devices connect normally, and the network communicates normally with all connected devices).
- When the cable modem is connected directly to the PC, internet connectivity is restored and functions normally.
- When the cable modem is reconnected to the router and everything power-cycled (modem powered on first then the router), internet connectivity returns for several seconds to a minute, then fails.
- I have reflashed the firmware successfully with no change
