fossildoc's avatar
fossildoc
Follower
Sep 27, 2017
WNDR4500 port forwarding with fixed IP address
I have 3 wired PCs and 1 wi-fi PC connected to my WNDR4500 router. One of my wired PCs has a local address of 10.0.0.7; I want to set up a home brew html server on that machine. I followed the instructions for port forwarding, but got stuck on page 99 of the manual, which says "In the Port Forwarding screen, configure the router to forward the HTTP service to the local address of your web server at 192.168.1.33. HTTP (port 80) is the standard protocol for web servers." I do not see any place on the Port Forwarding screen for entering a local address, unless I replace 10.0.0.7, which definitely does not work (the system replaces 192.168.1.33 with 10.0.0.7). There is no screen image in the manual for this step. I'd like, please, excrutiatingly detailed instructions for forwarding port 80 traffic to my 10.0.0. 7 PC, with or without a fixed IP address. I'm not even sure what the difference is between a fixed and a dynamic IP address is in this context. If I need to go to another screen, please indicate that.
1 Reply
  • > [...] my WNDR4500 router.
       Plain WNDR4500, not v2 or v3?  Not really a "Cable Modems & Routers"
    item, more of a plain-old router.  Is there a cable modem feeding this
    thing?  Is that thing in a bridge mode, or will a user in the outside
    world need to bore through two routers (cable modem+router and WNDR4500
    router) to get to your Web server?
       So, some version of Windows?  Ok.  But you need to fix (make
    constant) that address, because the port-forwarding rule will include a
    target IP address, and if your PC address changes, any port-forwarding
    rule which points to it will fail.  There are two ways to do that.  On
    the router, you can reserve an address for it, perhaps under ADVANCED >
    Setup > LAN Setup : Address Reservation.  Or, on the PC itself, you can
    specify all the addresses manually, instead of using DHCP
    ("automatically").  Reserving an address for it on the router is
    probably easier.  I generally shrink the DHCP pool ("Single/Start IP
    Address" and "Finish IP Address", so that there are some addresses
    outside the pool, and then I use those non-pool addresses for such
    reservations.
    > [...] I do not see any place on the Port Forwarding screen for
    > entering a local address, unless I replace 10.0.0.7, [...]
       The router Web form should fill in the subnet parts, "10.0.0", and
    you should fill in the host part, like, say, ".7", to get a whole
    address like "10.0.0.7".
    > I'd like, please, excru[c]iatingly detailed instructions for forwarding
       If it's not fixed, then your PC may very well wander away to another
    address the next time it or the router is rebooted.  You want it fixed,
    one way or another.
       A static address is one which the device knows on its own, without
    asking anyone else.  In Windows, that's the "Use the following IP
    address" choice.  (Using that requires you to know how to fill in all
    those fields: IP address, Subnet mask, and Default gateway.
       A dynamic address is one which the device gets from a Dynamic Host
    Configuration Protocol (DHCP) server (like your router).  (When the
    device starts up, it broadcasts a "Help me!" message.  The DHCP server
    responds with all the required data.)  In Windows, that's the "Obtain an
    IP address automatically" choice.
       A static address is always fixed.  A dynamic address is fixed if the
    DHCP server always responds (to a particular device) with the same data.
    (The DCHP server can identify a particular device by its MAC address,
    which is a hardware property.  Strictly speaking, that "Help me!"
    message is really more like "Help me!  My MAC address is [for example]
    11:22:33:44:55:66.")  If the DHCP server gets a request from an
    unrecognized MAC address, then it pulls a free IP address out of its IP
    address pool, and returns that.  If the DHCP server has a reserved IP
    address for that MAC address, then it returns that.
       So, what I might do in your situation would be to shrink the DHCP
    pool from (I assume) ".2" - ".254" (which is practically everything in
    the subnet) to something like, say, ".2" - ".199".  That pool would
    accommodate 198 devices, leaving ".200" - ".254" available for use as
    reserved addresses.  (This kind of division makes it easy to distinguish
    one set from the other in a list of attached devices, too.)
          ADVANCED > Setup > LAN Setup : Use Router as DHCP Server ...
       Then I'd reserve an address for the PC in the ".200" - ".254" range.
    First, determine the MAC address of the (network interface of the) PC.
    It should appear in the attached devices list:
          ADVANCED > Administration > Attached Devices
    Then, choose a (new) address for the PC from the ".200" - ".254" range,
    and reserve it:
          ADVANCED > Setup > LAN Setup : Address Reservation
    For example, 10.0.0.207.  When this has been done, reboot the PC, and
    verify that its address is the new one (10.0.0.207).  (If that failed,
    then I'd shut down both the router and the PC, then restart both.)
       Finally, create the port-forwarding rule, with external port 80 being
    forwarded to internal port 80 at IP address 10.0.0.207 (or whatever you
    reserved for the PC).  On my D7000, "HTTP" is one of the predefined
    services ("Service Name"), so this may be easy.
          ADVANCED > Advanced Setup > Port Forwarding / Port Triggering
       The post-final worry is whether your cable modem is also a router.
    If so, then you may need to take further steps to make your new Web
    server visible to the outside world.  However, in the mean time, if the
    Web server on your PC is running, then you should be able to reach it at
    the PC's LAN address (like http://10.00.0.207), or at the router's WAN
    address:
          ADVANCED > Setup > Internet Setup : Internet IP Address
       If that much works, then look at that "Internet IP Address" of the
    router.  If that's a 192.168.x.y, or 10.x.y.z, or some other private
    (non-routable) address, then you'll need to decide how to deal with the
    cable modem+router, so that it won't be blocking access from the outside
    world.
       Sufficiently excruciating?
