ROOM237
Apr 20, 2020Aspirant
WNR1000v.2 as a bridge with My C3700?
Hello all. How does one boost WiFi coverage with a C3700 Modem/Router and a WNR1000v.2? Is it possible to connect them wirelessly or do they have to be wired together? Thank you in advance for gi...
- Apr 28, 2020
The WNR1000 is getting to be fairly old. I would look into something a bit newer to use with the C3700 for a wireless bridge.
Apr 20, 2020Guru - Experienced User
I would review the WNR1000 user manual to see if there is any wireless briding or repeater features. If you don't see anything, then that model router doesn't support those features. You may want to review the EX3700 extender model...
