katinmo3
Jul 13, 2017Aspirant
WNR2000v4 Computer constantly connected to modem.
I am unable to turn off my internet connection on my computer. Due to limited satellite data, we want to turn it off to save data. When I click the internet access to turn off, it only turns off th...
- Jul 16, 2017
You can always unplug the Ethernet cable from your computer. :-)
If you want to shut it off in Windows, start by right-clicking on the pitch fork icon and click on Open the Network and Sharing Center. You will see something like this:
Click on Change adapter settings on the left. You will see something like this:
Click on the icon that looks like the one labeled Ethernet in this picture. Your icon may have a different name. If you have more than one icon that looks the same, click on the one without the red X. Once you click on the icon, the option Disable this network device should appear. Click on that. Verify that Internet access has been disabled.
You can enable Ethernet by repeating this process. You will click on the same icon (except that it will show a red X) and then click on the option Enable this network device.
katinmo3
Jul 16, 2017Aspirant
That did it! Thanks so much! đ
