dhsimons's avatar
dhsimons
WNR2000v4 Genie Network Map has incorrect data
While trying to correct a problem, I inadvertently supplied information that resulted in an incorrect Genie Network Map. (It displays, in the center, the router/modem that connects to the internet, r...
  • dhsimons's avatar
    Aug 31, 2016
    I corrected this problem by resetting the router.
