Craig_Mace
Sep 13, 2019Aspirant
WNR2000v5 trying to get it to recognize modem
Trying to connect this router to a modem it hasn't seen before, followed all the on line instructions up until connection to a computor. The instructions then said open new broswer on computor and fo...
Sep 14, 2019Guru - Experienced User
Are you reading the manual, install guide?
If you go to the install guide it says to type in routerlogin.net and follow the setup process. Did you type that in?
If you're not able to do that the manual has the manual install process as well that you can try.
Here's the link to the support site. It has the manual, install guide, and firmware.
- Craig_MaceSep 14, 2019Aspirant
Got it sorted, thankls for the assistance, cheers.................Craig
