virtualgeek76
Nov 13, 2021Aspirant
WNR2200 initial firmware
I have a WNR 2200 router and my doorm mate flashed it with DD WRT without asking and I want to change it back to the Netgear image but I need the initial firmware image. I looked via the support page...
Nov 13, 2021Guru - Experienced User
get it here:
https://www.netgear.com/support/product/WNR2200.aspx
Click on downloads----->"+view previous versions"
that'll have all the versions
- virtualgeek76Nov 14, 2021Aspirant
Thanks but the initial image is not listed there, I have tried the oldest but it doesn't appear to be the right one as I need it to reimage from DD-WRT back to Netgear
- plemansNov 14, 2021Guru - Experienced User
You shouldn't need the initial firmware version when removing the ddwrt setup. But you do need to check the ddwrt forum for help with removing it. The official forums aren't where you're going to find the best help for removing 3rd party firmware.
