redwings9798
Dec 28, 2018Follower
WNR3500Lv1 - Access Point
Attempting to use the WNR300Lv1 as an access point. Have latest firmware uploaded. Can get to internet via Ethernet and wireless though it, but cannot see computers on main router. Firmware automatically gave this router the 10.0.0.1 IP address, but when I move the Ethernet line from the main router to the access point router from WAN to LAN, I can see the other computers, but lose the wireless connections. The software/firmware for this router doesn't have a Wireless AP select option, even though It shows "ON" in the advanced wireless settings.
1 Reply
> Attempting to use the WNR300Lv1 as an access point. [...]
How, exactly?
> [...] Have latest firmware uploaded. [...]
As always, an actual version number (when available) would be more
useful than your opinion of what's "latest" today. Probably not
critical in this case, however.
> [...] Firmware automatically gave this router the 10.0.0.1 IP address,
That will happen when its WAN/Internet port is connected to some
other router which is already using its preferred (192.168.1.*) subnet.
> [...] The software/firmware for this router doesn't have a Wireless AP
> settings.
That setting refers to the WAP as used by the router in its normal,
full-function router mode. "ON" is good, but it doesn't disable (or
evade) the normal router functions, which is what you want.
> [...] when I move the Ethernet line from the main router to the access
> the wireless connections. [...]
Almost any wireless router can be configured as a WAP, but, to
arrange that, you need to make more configuration changes than moving a
cable. For one step-by-step on how to do this, see:
https://community.netgear.com/t5/x/x/m-p/1463500
That's written for a C6300, but the steps are about the same for any
other router (any make/model) which lacks a one-step WAP option,
including yours.
