Tracy76's avatar
Tracy76
Follower
Dec 24, 2016
Wont connect to amazon fire stick
The fire stick dose recognise rhe netgear wifi booster and i can select it ..but then a page on my tv pops up to join netgear and its blank and gives me no options ..so i go off the page ...and check network connections ..it says that the fire stick is connected with problems but wont let me access my shows as though its not connected
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Tracy76
    Are your trying to connect to a routers network or a extenders network also what is a model of the netgear product.
    DarrenM
