Retired_Member
Feb 05, 2023Work VPN not working on Nighthawk Ax8 combo
I've been trying so hard to work from home but all have so far failed with the gateway. All ports necessary for my work VPN have been opened, and Security taken care of, talked to my ISP and they gua...
Feb 06, 2023Guru - Experienced User
What NH router products do you have? Ax8 isn't a model #.
R or RAX or MK something?
Retired_Member
Feb 06, 2023- Nighthawk' AX8/8 Stream WiFi 6 Cable Modem Router
CAX80-100NAS
AX6000 WiFi Cable Modem Router
DOCSIS® 3.1 - Built-in Cable Modem
I am at work so that is what I have on the pictures I have. Would that help?
