Astral_Klutch
Jan 16, 2024Aspirant
Xbox connection problems
I’ve been having this problem for a long time now. Ironically it’s gotten worse since upgrading to my Nighthawk AC1900 C7000. But the problem comes down to only the Xbox Series X When it comes to t...
Jan 17, 2024Guru - Experienced User
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
Is the xbox wired or wireless connected to the modem? Wired is preferred.
Has a factory reset and setup from scratch been performed?
- Astral_KlutchJan 17, 2024AspirantThe Xbox is on a wireless connection. As for cable connection and event logs what exactly am I supposed to copy & paste?
Also I just bought the router not long ago. So brand new with having to add the required ports for Xbox- FURRYe38Jan 17, 2024Guru - Experienced User
You don't need to set up for configure any ports for use with xbox. if you do then you'll need to disable uPnP on the modem.
Please copy and paste the entire web page data from those two locations in your next post or put into a document and save off as a PDF file and attach to your next post.
What channels are you using on the modem for 2.4 and 5ghz radios?
Is Smart connect enabled?
How far is the xbox from the modem in distance feet?
- Astral_KlutchJan 17, 2024AspirantMy 2.4 is on channel 10 while my 5G is on channel 36. And I do believe smart connect is enabled.
