Astral_Klutch
Jan 16, 2024Aspirant
Xbox connection problems
I’ve been having this problem for a long time now. Ironically it’s gotten worse since upgrading to my Nighthawk AC1900 C7000. But the problem comes down to only the Xbox Series X When it comes to t...
Jan 17, 2024Guru - Experienced User
Ok, first thing, power levels to the modem are too high:
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
Need to have the ISP turn these down or install a -3 to -6db attenuator to help reduce the power.
Any Criticals, Errors or Warnings seen in the event logs needs to be reviewed and resolved by the ISP. Indicates a signal issue on the ISP line up to the modem.
There are some correctables and un-correctables that should be zeros like the other channels show.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
https://highspeed.tips/docsis-events/
Smart Connect will be on the modems web page under Basic Tab/Wireless settings if it's supported here.
Astral_Klutch
Jan 17, 2024Aspirant
So since my primary ISP is Spectrum should I go through them or does Netgear handle everything on that end?
- FURRYe38Jan 17, 2024Guru - Experienced User
That all is handled and ISP responsible. Even FW updates.
