rkinneyest
Nov 16, 2022Follower
xbox one & c6250
Ever since i got the c6250 when I start the xbox (connected via ethernet) it does not connect to Xbox Live due to NAT or UPnP issues. i was able to get online at one point (after 6 hours of tinkering)...
Nov 16, 2022Guru - Experienced User
Is the console wired or wireless connected to the modem? Wired is preferred.
Has a power off for 1 minute then back ON with the modem been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed?
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
