xMichelangelox
Dec 24, 2018Aspirant
Xbox one X will connect via wif but not with an Ethernet
I have tried all the basic things and cannot resolve the issue. Someone please help ASAP. This has to be a setting issue. ive tried two diffrent ethernets and they both have the same problem. ive put...
DarrenM
Dec 28, 2018Sr. NETGEAR Moderator
Have you tried to reserve the Ip address of the xbox?
https://kb.netgear.com/25722/How-do-I-reserve-an-IP-address-on-my-NETGEAR-router
DarrenM
xMichelangelox
Jan 12, 2019Aspirant
i tried through the xbox but dont know how to do set it up on the router
- xMichelangeloxJan 12, 2019Aspirant
Did this did not work
- Nodism1125Jan 14, 2019NETGEAR Expert
Please follow the steps below.
Start on Xbox One's Dashboard.
Navigate to Settings > All Settings.
From there, choose Network > Network Settings > Advanced settings.IP: 192.168.0.100
SM: 255.255.255.0
DG: 192.168.0.1DNS1: 8.8.8.8
DNS2: 8.8.4.4In the same menu, select IP Settings > Manual. You will be prompted to enter an IP Address, Subnet mask and Gateway. Please use the details you wrote down earlier to populate the fields.
Then, go back to the Advanced Settings screen and select DNS Settings. Enter Primary and Secondary DNS Address from your notes.
Back on the Advanced Settings screen, please press Save. You have now set a static IP address for your Xbox One.
- xMichelangeloxJan 14, 2019Aspirant
this did not work will show wired for brief second but will not consistantly connect for more than 4 seconds
