richki02
Jun 17, 2020Guide
Xfinity Compatible Modem Recommendations
Like most - I'm working from home through the end of the calendar year (with heavy downloads / uploads of files + zoom/teams video conferences throughout the day). this is coupled with schooling fro...
Jun 18, 2020Guru - Experienced User
What speeds do you pay for or plan on paying for? (upload and download)
How big is your home?
What are your interior walls made of?
How many devices total do you plan on supporting?
depending on all that, I'm a fan of the netgear Orbi. Its great for providing coverage with great speeds. And its easily expandable if you need better coverage or more satellites. And it has the option of wireless or wired backhaul.
richki02
Jun 18, 2020Guide
Thanks for your help. Here's some additional info to your questions...
* up to 275mbs download / 10mbs upload
* 3000 sq ft but want to get a bit of coverage outdoors
* Mainly wood and dry wall (probably some steel joint support)
* 10-20 across 5 folks in the family (all working, schooling and entertaining at home - including lots of streaming, video conferencing, online gaming)
Not sure if I need a combo cable modem/router and other satellites. Or if I should go with a cable modem and then separate router/satellites? And in both cases - which ones. Hoping I could have selected these on my own but getting lost with the options.
