richki02
Jun 17, 2020Guide
Xfinity Compatible Modem Recommendations
Like most - I'm working from home through the end of the calendar year (with heavy downloads / uploads of files + zoom/teams video conferences throughout the day). this is coupled with schooling fro...
Jun 18, 2020Guru - Experienced User
First check with the ISP to see what they support before buying.
NGs CM1000/1100 are recommended.
richki02 wrote:Like most - I'm working from home through the end of the calendar year (with heavy downloads / uploads of files + zoom/teams video conferences throughout the day). this is coupled with schooling from home, other (4) members on the family constantly online and upcoming addition of home security cams. so need to maximize the pipeline i'm getting from xfinity and spread it through and just outside my home (for security cams). can folks recommend xfiinity cable modem and routers/satellites? thx for your help.
richki02
Jun 18, 2020Guide
Thanks for your reply and suggestions. Looks like my bandwidth is much lower than yours - perhaps that's one of the issues. Just not sure if they offer more than what I'm paying for now. I'll check. But per your notes - if I'm reading it right:
1) You use the Nighthawk AX8 as your cable modem and then use the Orbi RBK853 as your wifi router.
2) and then second your "additional" are other options/variations. Some with dedicated cable modem. And some like the CBK40 which is a combo cable modem/router.
For additional: do you recommend a dedicated cable modem over a cable modem/router combo?
Thanks for your help.
