richki02
Jun 17, 2020Guide
Xfinity Compatible Modem Recommendations
Like most - I'm working from home through the end of the calendar year (with heavy downloads / uploads of files + zoom/teams video conferences throughout the day). this is coupled with schooling fro...
Jun 18, 2020Guru - Experienced User
I'm a fan of a seperate modem and router.
Reason why is the ISP controls the firmware on modems and modem/router combo devices.
So by buying them seperate, you can upgrade the firmware yourself. As well as if the modem side goes bad, you're out the modem and the router.
Its a bit more of a buy in but offers more options to upgrade, replace, repair, and update.
In terms of modem, I'd look at whats compatible with your service with xfinity and if you plan on upgrading. They have a recommended devices page on their web portal for your service.
For the router I'd recommend any of the triband orbi's. They work great and can be easily expanded. I'd avoid the dual band orbi (cheapest models).
richki02
Jun 18, 2020Guide
Thank you for these insights and quick reply. Much appreciated.
