Fortuona
Dec 05, 2021Aspirant
Xfinity disables 2.4Ghz on CAX30
My CAX30 will broadcast on 2.4GHz and 5GHz up until the moment I activate it with Comcast Xfinity, at which point I only have access to the 5GHz band. Admin controls say it is still working but none...
Fortuona
Dec 07, 2021Aspirant
I am not using smart connect. And I haven't done a wireless scan using something other than windows on the computers (I'm afraind I don't know how), but the android devices, the printer, and the smoke alarm don't see it either.
Thanks for thinking about it.
Dec 07, 2021Guru - Experienced User
You can try doing a scan using inssider or any of the general wifi scanners that can be downloaded. there's quite a few of them. I use inssider or winfi
- FortuonaDec 07, 2021Aspirant
Thank you for this. With Winfi Lite, I do see the 2.4 GHz band is present. Though, I'm not sure how to apply this good news to getting my printer and smoke alarm to see it now the we know that it is actually there.
Do they have a Winfi equilivalent for old HP printers and Nest smoke alarms? (she asks optimistically)- plemansDec 07, 2021Guru - Experienced User
Is you ssid broadcast disabled in the router?
No, both bands are broadcasting. When I disable broadcasting the 5Ghz, it shuts off just as expected and I have to go dig out the ethernet cable, but not suprisingly, has no effect on the other band. Toggling the 2.4 GHz SSID broadcast has no effect.
