Fortuona
Dec 05, 2021Aspirant
Xfinity disables 2.4Ghz on CAX30
My CAX30 will broadcast on 2.4GHz and 5GHz up until the moment I activate it with Comcast Xfinity, at which point I only have access to the 5GHz band. Admin controls say it is still working but none...
Dec 07, 2021Guru - Experienced User
You can try doing a scan using inssider or any of the general wifi scanners that can be downloaded. there's quite a few of them. I use inssider or winfi
Fortuona
Dec 07, 2021Aspirant
Thank you for this. With Winfi Lite, I do see the 2.4 GHz band is present. Though, I'm not sure how to apply this good news to getting my printer and smoke alarm to see it now the we know that it is actually there.
Do they have a Winfi equilivalent for old HP printers and Nest smoke alarms? (she asks optimistically)
- plemansDec 07, 2021Guru - Experienced User
Is you ssid broadcast disabled in the router?
- FortuonaDec 07, 2021Aspirant
No, both bands are broadcasting. When I disable broadcasting the 5Ghz, it shuts off just as expected and I have to go dig out the ethernet cable, but not suprisingly, has no effect on the other band. Toggling the 2.4 GHz SSID broadcast has no effect.
What I've ended up doing as a temporary solution is activating an old 2.4Ghz only Netgear C3000 modem/router with xfinity (despite all their warnings not to) and setting up the network as I want the new 2.4GHz network to look. I connected all my older devices to this network and while leaving the router portion running transfered the service to the CAX30. Then I set up the 5 GHz band and made sure everything there was working before changing the 2.4GHZ band on the CAX30 to match the C3000. This made everything angry but when I shutdown the C3000 all the devices jumped to the CAX30.
Of course doing this meant I that I couldn't properly activate the CAX30 through Xfinity and I had to call them in order for them to do it manually.It may work in a pinch, but this is an unreasonable process for every power outage. On top of having Xfinity I also have PG&E.
