Fortuona
Dec 05, 2021Aspirant
Xfinity disables 2.4Ghz on CAX30
My CAX30 will broadcast on 2.4GHz and 5GHz up until the moment I activate it with Comcast Xfinity, at which point I only have access to the 5GHz band. Admin controls say it is still working but none...
Fortuona
Dec 07, 2021Aspirant
What I've ended up doing as a temporary solution is activating an old 2.4Ghz only Netgear C3000 modem/router with xfinity (despite all their warnings not to) and setting up the network as I want the new 2.4GHz network to look. I connected all my older devices to this network and while leaving the router portion running transfered the service to the CAX30. Then I set up the 5 GHz band and made sure everything there was working before changing the 2.4GHZ band on the CAX30 to match the C3000. This made everything angry but when I shutdown the C3000 all the devices jumped to the CAX30.
Of course doing this meant I that I couldn't properly activate the CAX30 through Xfinity and I had to call them in order for them to do it manually.
It may work in a pinch, but this is an unreasonable process for every power outage. On top of having Xfinity I also have PG&E.
Dec 07, 2021Guru - Experienced User
I'd make contact with NG support on this and let them know what your experiencing...
- FortuonaDec 07, 2021Aspirant
I have. The person I spoke to went through the basics, then refered me to higher ups who would call "soon". That was a few days ago. I'm not sure what kind of "soon" to expect, so I thought I check with you very smart folks to see if anyone had any ideas.
I appreciate the help getting it limping along. - FURRYe38Dec 08, 2021Guru - Experienced User
I would keep in touch with support. You'll need to use that 2ndary wifi AP for now until this is resolved.
- FortuonaDec 09, 2021Aspirant
Thanks. I'll update with a solution is we get to one. I appreciate everyone's effort.
- JonastranceJul 19, 2022AspirantDid you ever get a resolution? I'm having this same trouble and it's driving me insane trying to figure it out.
