Fortuona
Dec 05, 2021Aspirant
Xfinity disables 2.4Ghz on CAX30
My CAX30 will broadcast on 2.4GHz and 5GHz up until the moment I activate it with Comcast Xfinity, at which point I only have access to the 5GHz band. Admin controls say it is still working but none...
Dec 07, 2021Guru - Experienced User
I'd make contact with NG support on this and let them know what your experiencing...
Fortuona
Dec 07, 2021Aspirant
I have. The person I spoke to went through the basics, then refered me to higher ups who would call "soon". That was a few days ago. I'm not sure what kind of "soon" to expect, so I thought I check with you very smart folks to see if anyone had any ideas.
I appreciate the help getting it limping along.
- FURRYe38Dec 08, 2021Guru - Experienced User
I would keep in touch with support. You'll need to use that 2ndary wifi AP for now until this is resolved.
- FortuonaDec 09, 2021Aspirant
Thanks. I'll update with a solution is we get to one. I appreciate everyone's effort.
- JonastranceJul 19, 2022AspirantDid you ever get a resolution? I'm having this same trouble and it's driving me insane trying to figure it out.
