djohnson223
Nov 28, 2017Initiate
Xfinity GIG service slow
Just installed a CM1000 and I am getting speeds from 320 to 500 on Xfinity Gig Sevrvices. With the Xfinity Modem I was getting 500 to 900. Has anyone had this problem and if so what was the solution to fix the issue?
1 Reply
- DarrenMSr. NETGEAR Moderator
Have you had the ISP double check the coding on the modem to make sure its assigned the correct speed for the gig service?
DarrenM
