darkraven797
Oct 03, 2020Follower
Xfinity Gigabit not working CM1000 - only getting around 90 Mbps down
Hello! Was hoping I could get someone to check out the screenshot attached and give me some pointers. I am currently troubleshooting an issue where I did have gigabit internet from XFinity back ...
Oct 03, 2020Guru - Experienced User
Your cable connections look good.
The fact that you put 95mbps make me think the router is negotiating a 10/100 mbps connection and not gigabit.
what router do you have?
What pc are you testing on? is it gigabit?
are you going through the router or trying directly connected to the modem?
