funkstatic
Dec 11, 2018Aspirant
xfinity I'm only able to load ipv6 webpages, ipv4 doesn't work
I just got a CM1000 to upgrade my modem, and after going through setup with comcast, the only webpages I can load are ipv6 ones (google, youtube, xfinity site.) Ipv4 ones don't work at all. I've be...
- Dec 11, 2018
I performed another factory reset on the modem, and then used the gf's pc to connect to it, which worked.
All of a sudden everything is functioning normally... and I'm able to load all webpages of both types.
No idea why the first attempts at factory resets didn't get me there, but whatever it works now!
funkstatic
I will also add that currently I'm testing without a router, just running directly into my computer.
- antinodeDec 11, 2018Guru
> [...] I'm completely unable to access my modem settings through it's
> IP address. [...]
Which "[its] IP address" is that? Determined how? Have you tried
"192.168.100.1"?
> [...] I'm testing without a router, just running directly into my
> computer.
What's the IP address of your (unspecified) "my computer"?- funkstaticDec 11, 2018Aspirant
Yes I'm trying to connect to 192.168.100.1. It just times out and says it can't connect. Even pinging that IP returns nothing, which seems strange.
