ilikecerealtoo
Jul 15, 2022Tutor
Xfinity is my provider and all I can get is the top COAX WAN lights
I am having the exact same issue! Xfinity is my provider and all I can get is the top COAX WAN lights. I have done everything, all the resets, all the power-offs. Even the 30-30-30 reset (which I d...
ilikecerealtoo
Jul 18, 2022Tutor
Oh yeah... the tech came by Sunday morning (Jul 17) and this situation is wild. After testing the coax line she was on the phone with someone (engineering team?) After about 1 hour she made an engineering ticket. I don't use the Xfinity line for anything but my modem so it comes straight from the wall box into my modem, no splitters or anything. Signal is great. The modem is successfully connecting to Xfinity for 5-10 minutes before restarting... endless loop.
My hope is that Xfinity will push out a new firmware flash to me because there is not a reset I have not yet tried. They claim that isn't something they do for customer devices but we all know they do ninja flash our CAX80 firmware 2-3x a year.
My issue seems far worse than most other people have reported. There is no router page I can even access. No wireless is being broadcast (I did try the front wifi button). No wired connection works, like the blinky port lights don't even blink when connected. Both PC and Mac report no connection. I have many known good CAT6 cables so it isn't the ethernet cable.
Firmware is (was?) 2.1.3.7
Jul 18, 2022Guru - Experienced User
The only FW that users can NOT apply to the modem is the modem portion of FW. There is user updatable FW for the router portion of the Modem. ISPs ARE responsible to push FW to the modem side of the modem.
The reboots of the CAX80 inidicate that the signal on the line has dropped to a bad level or is no longer present on the line, thus is triggers the CAX to continually reboot until a signal on the line is present and working. The ISP needs to look into this.
Do you have a screen capture of the Events Log and Cable Connections status page?
