djjazzyjeff's avatar
djjazzyjeff
Follower
May 30, 2019
Xfinity Modem Question
Hello,
I recently purchased the modem that advertises it can act as replacement to an Xfinity modem. My question is that if my family were to switch our cable provider (to say hypothetically AT&T) would the modem still work?
Thanks!
  • > I recently purchased the modem [...]
    > Model: CM1150V|DOCSIS 3.1 Nighthawk. Multi-Gig Speed Cable Modem for
    > XFINITY. Voice
       Is _that_ your "the modem"?
    > [...] if my family were to switch our cable provider (to say
       It might, if your hypothetical AT&T service were the cable-TV type.
    If it were some kind of DSL, then you'd need some kind of DSL modem
    (which a CM1150V is not).
  • FURRYe38's avatar
    ATT doesn't have cable ISP services, they are mostly DSL and Fiber. The CM1150v is a cable modem only. Can only be used on cable modem ISPs.
    djjazzyjeff wrote:
    Hello,
    Thanks!
