helpme-thankyou
Mar 15, 2021Aspirant
Xfinity says AC1900 c7000 v2 is not compatible for 35 mbps upload speed?
Xfinity says AC1900 c7000 v2 is not compatible for 35 mbps upload speed? Is that correct? If yes, What can net gear do to help me address this gap? I would like to not waste the modem and not even sur...
Mar 15, 2021Guru - Experienced User
Check the specs sheet. I believe that model supports well over that on the UP.
- helpme-thankyouMar 16, 2021AspirantThanks for the suggestion. The spec sheet here doesn’t talk about upload speeds. Only talks about download speed up to 960 mbps. I like to get 35 mbps upload speeds too. Link here -https://www.netgear.com/images/datasheet/networking/CableModems/C7000.pdf
- plemansMar 16, 2021Guru - Experienced UserSorry missed the upload. The only time I've gotten >35 Mbps was on a docsis 3.1 modem and Gigabit plan
