helpme-thankyou
Mar 15, 2021Aspirant
Xfinity says AC1900 c7000 v2 is not compatible for 35 mbps upload speed?
Xfinity says AC1900 c7000 v2 is not compatible for 35 mbps upload speed? Is that correct? If yes, What can net gear do to help me address this gap? I would like to not waste the modem and not even sur...
Mar 16, 2021Guru - Experienced User
I would try contacting xfinity again. It supports up to 400mbps on xinfity as far as I'm aware.
Maybe you just had a tech that was stuck on upselling you on speeds or didn't know what they were doing.
