smbaligh
Jun 14, 2021Aspirant
XFinity says I am not getting speed because of my router
Not getting enough speed, I have a 100Mbps connection and I only get 25-30Mbps, Although this is Xifnity certified router but based on my call with XFinity earlier today, Net Gear routers are not goo...
Jun 15, 2021Guru - Experienced User
Are you testing wireless or wired into the router?
What device are you using for testing?
Do you have a screen snip of the cable connections page and the modem event logs?
smbaligh
Jun 15, 2021Aspirant
I am testing it on wireless (WiFi)
Testing speed on my MacBook Pro
I am not sure how can I get it, Can you share any link I can follow to get the logs?
- plemansJun 15, 2021Guru - Experienced User
Test it wired.
The C3000 isn't dual band. And 2.4ghz is a slow network and its sensitive to inteference.
Its the reason for dual band routers. In this day, I don't recommend single band routers unless you live in the country with no one around and you're using dialup/dsl.
