DudeRides
May 20, 2026Aspirant
Xfinity Says I Need To Replace My CM3000
Hello, A couple of days ago I had a technical support call with Xfinity regarding a streaming issue. During the call, they checked modem status and claimed that the modem was generating errors. T...
CrimpOn
May 20, 2026Guru - Experienced User
Here's hoping that the information helps place the blame squarely on the modem or the cable. If it does not....
Perhaps a silly question..... If you have Xfinity install a modem, how long are you required to keep it?
I see two obvious ways to settle the question of "is it the modem or the cable?"
- Spend over $150 to buy a new Xfinity compatible modem
https://www.xfinity.com/support/internet/customerowned
If the streaming problems go away and the new modem does not report the same errors as the existing modem, then the original modem was probably bad.
If the streaming problems remain and the new modem reports the same sort of errors as the original modem, it is probably the cable. - Have Xfinity install their modem (at about $15/month).
If the streaming problems remain with the Xfinity modem, then the problem is with the cable and Xfinity needs to fix it.
If the streaming problems go away, then the original modem was bad and you now get to make the same decision as before. "Is it better to spend $15/month to rent an Xfiniity modem or to buy my own modem?"
I would probably go with, "install an Xfinity modem" to save the potential hassle of returning a modem if it turns out that the cable was bad.
DudeRides
May 22, 2026Aspirant
I thought this was an excellent idea, so I have an Xfinity gateway on the way. I will need to switch it to bridge mode so it will work as a modem only, as I have a router already in place, however, this will be a good test of the line signal quality assuming I can get Xfinity to perform an honest remote test of modem condition.
- CrimpOnMay 22, 2026Guru - Experienced User
Please comment on how things go. and...... what is behind the decision to install a gateway rather than just a modem?
(does Xfinity no longer install modems?)
- DudeRidesMay 23, 2026Aspirant
Xfinity would only supply a gateway. They would not send a simple modem. I've looked into how to boot it and switch it to bridge mode so it will function as a modem only.
