awitek
Jul 23, 2016Aspirant
Xfinity Speed slow with C7000 and R8500 Nighthawk
My setup is a C7000 modem connected to a R8500 router, with the router setup as an AP. I have Xfinity Blast! internet service at 150Mbps. When running Xfinity speed test on a wired connection or th...
awitek
Jul 26, 2016Aspirant
I think the cables are fine. I also swapped them out with different ones, and it didn't change anything.
Other than the wifi and login passwords, the C7000 and R8500 are set at factory defaults.
I think the information provided on the Cable Connection is ok, and i'm not sure what to make of the informtion provided in the logs. Copies of them are below.
The only "strange" item I found is that "Europe" is selected for the Region Selection found in the Wireless Setup. I can't chnage it to anything else because the pull-down selection box is locked-out.
Advanced -> Administration-> Log:
| Description | Count | Last Occurrence | Target | Source |
| [admin login] from source 192.168.0.14 | 1 | Tue Jul 26 17:44:00 2016 | 0.0.0.0:0 | 192.168.0.14:0 |
| [admin login failure] from source 192.168.0.14 | 1 | Tue Jul 26 17:43:54 2016 | 0.0.0.0:0 | 192.168.0.14:0 |
| [admin login] from source 192.168.0.14 | 1 | Tue Jul 26 17:35:22 2016 | 0.0.0.0:0 | 192.168.0.14:0 |
| [admin login failure] from source 192.168.0.14 | 1 | Tue Jul 26 17:35:14 2016 | 0.0.0.0:0 | 192.168.0.14:0 |
Advanced -> Administration -> Event Log:
| Time | Priority | Description |
| 1970-1-1, 00:00:38 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=b0:7f:b9:5c:c3:58;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:00:42 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=b0:7f:b9:5c:c3:58;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:00:42 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=b0:7f:b9:5c:c3:58;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:00:49 | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=b0:7f:b9:5c:c3:58;CMTS-MAC=00:01:5c:86:9a:6c;CM-QOS=1.0;CM-VER=3.0; |
| 2016-7-24, 06:37:48 | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=b0:7f:b9:5c:c3:58;CMTS-MAC=00:01:5c:86:9a:6c;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:00:37 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=b0:7f:b9:5c:c3:58;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:00:42 | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=b0:7f:b9:5c:c3:58;CMTS-MAC=00:01:5c:86:9a:6c;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:00:38 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=b0:7f:b9:5c:c3:58;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:00:41 | Notice (6) | WiFi Interface [wl0] set to Channel 1 (Side-Band Channel:N/A) - Reason:INIT |
| 1970-1-1, 00:00:41 | Notice (6) | WiFi Interface [wl1] set to Channel 153 (Side-Band Channel:N/A) - Reason:INIT |
| 1970-1-1, 00:00:45 | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=b0:7f:b9:5c:c3:58;CMTS-MAC=00:01:5c:86:9a:6c;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:00:53 | Notice (6) | Honoring MDD; IP provisioning mode = IPv6 |
| 2016-7-26, 10:39:05 | Warning (5) | TEK Invalid - Invalid Key Sequence Number;CM-MAC=b0:7f:b9:5c:c3:58;CMTS-MAC=00:01:5c:86:9a:6c;CM-QOS=1.1;CM-VER=3.0; |
Cable Connection:
Frequency start Value | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect. | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Startup Procedure | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Downstream Bonded Channels | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Upstream Bonded Channels | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Current System Time:Tue Jul 26 17:36:05 2016 |
DarrenM
Jul 28, 2016Sr. NETGEAR Moderator
Hello awetik
I do see some T3 timeouts so there is some type of noise on your line do you happen to have a cable splitter hooked up to the modem if so try to remove it and go directly to the wall and test to see if that improves the speeds. If not you may want to ask your ISP to send a Tech out and check the lines to see if there is a issue.
http://volpefirm.com/docsis_timout_descriptions/
DarrenM
