bmillerct
Feb 09, 2022Follower
Zoom Issues
Actual modem router is AC1900 C6300BD Have been getting dropouts on Zoom when using my MAC desktop. Zoom pop-up says its intermittent network connection. Desktop is set up to use the 2.4 WIFi conn...
Feb 10, 2022Guru - Experienced User
use the 5ghz.
2.4ghz is a slower network and more sensitive to interference than 5ghz.
So use the 5ghz.
If that doesn't help, then use the wired connection.
If that doesn't help, it could be a speed/modem issue
