ITstress
Sep 20, 2021Follower
Firmware out of date
My phone app only says "firmware is out of date" There is no "update" button any where. Someone recommended to go to routerlogin.net I went to that screen but there is no "Update firmware" choi...
michaelkenward
Sep 21, 2021Guru - Experienced User
If you own the C6300, that is down to a bug in the app.
Nighthawk app same "firmware not updated" when it ... - NETGEAR Communities
Note the Netgear response:
Re: Nighthawk app same "firmware not updated" when... - NETGEAR Communities
Your firmware is not out of fate. At least, it may be but there is nothing you can do about it.
If your firmware is outdated, you cannot manually upgrade your cable modem’s or modem router’s firmware. You must contact your Internet service provider (ISP) to upgrade your firmware.
