Solarsails
Dec 02, 2020Aspirant
Grey or greyed out NEXT BUTTON in NETGEAR ROUTER firmware +found with other button WORKAROUND SOLVED
NETGEAR ROUTERS: "NEXT BUTTON" is (grey,greyed) when attempting to use the NETGEAR GENIE wizard to configure an ACCESS POINT. (A grey button is essentialy disabled or not enabled and will not function.)
The following describes a rather frustrating bug that you have probably encountered while working with a NETGEAR ROUTER.
I will help you to address and work around the issue (bug) that you have encountered while using the NETGEAR GENIE APP to manually configure your NETGEAR ROUTER to be an ACCESS POINT / AP. This problem is encountered on the 'network name and security settings' page (can be found on other firmware pages) and manifests as a disabled (grey or greyed out) NEXT button which prevents the user from continuing to the next configuration menu page.
1 Reply
I had the same exact problem with Chrome on WIndows 11 and Android.
It worked in MS edge! Such a frustrating afternoon.....
My extender is now configured after a factory rest!! 🙂
