Garry4's avatar
Garry4
Latest firmware breakd D6200 web GUI, how do I roll back using the Genie?
Hi,
The latest firmware for the D6200 (V1.1.00.34_1.00.34) has broken the web GUI. I have tried Firefox, Chrome and Edge, all show a mostly text page. If I use the Genie to try and update (to roll back) the firmware it only has the online update option, not update using a file (I have downloaded the previous version)
How can I load firmware from a file without the web GUI?
I presume that a factory reset will still use the firmware currently running, rather than reverting to the version it shipped with??
Many thanks,
Garry
  • Garry4 wrote:
    I am able to log into the router using the browser interface, but the home page displayed is simply dumb text, with the exception of the logout text which in fact does allow me to log back out again. All the other text seems to be text only. (I have not explored the HTML behind the page)
    What does "simply dumb text" mean?
    Screen (Alt + Print Screen) shot?
    I assume that you tried routerlogin.net.
    You could try the more severe recovery reset:
    • Press reset for 30 seconds
    • Keep pressing reset while removing power
    • Keep pressing reset for another 30 seconds while apply power
    This might dislodge any corrupt settings in the firmware.
    There is another way of applying firmware:
    How to upload firmware to a NETGEAR router using Windows TFTP | Answer | NETGEAR Support
    In your case, unlike many of the people who need that, you start with the advantage that your D6200 is not bricked, with a flashing orange power LED.
  • michaelkenward's avatar
    michaelkenward
    And that text page says?
    What do the LEDs look like on the thing?
    Did you reset the router to factory settings after the firmware flash?
    New firmware sometimes introduces changes that are not compatible with the old configuration.
    So while it isn't guaranteed to fix problems a factory reset is the first thing to try if you have issues with new firmware.
    This is a nuisance because you then have to reconfigure the device all over again.
    You can backup your settings before you reset and restore them later. But that may just bring back the fault. Then again, at least you will know if the reset fixed the problem.
    Yes.
    • Garry4's avatar
      Garry4
      Hi,
      Thanks for your reply.
      I have attached a screenshot.
      Normal, three greens (Power, DSL and internet) and a blue (WiFi)
      No, I am about to try that tonight.
      Do you know if a release is a full release, or a patch? By that I mean is it possible that some resource used for the GUI isn't included in the release and it has somehow become corrupted? If so, may an earlier release include this?
      A random thought I know.
      Is there a menu item that I have missed in either the Android Genie or the Windows Genie that allows a file update rather than the online update?
      Again, many thanks.
      Garry
        michaelkenward
        Yes. Read the manual.
        There is support for the D6200 somewhere at the end of this link:
        >>> D6200 | Product | Support | NETGEAR <<<
        Look at the firmware downloads and read the release notes.
