HSBratt
May 12, 2017Aspirant
NetGear Genie Firmware Update and IPV6
While attempting to update the firmware on myGenie A3, I get an error message that the router is no longer supported or not found. Is the A3 no longer supported?
- May 17, 2017
Ok I am upgrading to a Netgear 750. Thanks for your input.
michaelkenward
May 13, 2017Guru - Experienced User
A3?
HSBratt
May 13, 2017Aspirant
Sorry it is the Netgear43. Can they make the font any smaller? :-)
- DexterJBMay 16, 2017NETGEAR Moderator
Hi HSBratt,
1. Netgear43 is the default SSID/WiFi name configured on the router. Please look for the exact model number (i.e. R7000).
2. Are you following the instructions on the link below?
http://kb.netgear.com/app/answers/detail/a_id/23960
Dexter
Community Team
