HSBratt
May 12, 2017Aspirant
NetGear Genie Firmware Update and IPV6
While attempting to update the firmware on myGenie A3, I get an error message that the router is no longer supported or not found. Is the A3 no longer supported?
- May 17, 2017
Ok I am upgrading to a Netgear 750. Thanks for your input.
HSBratt
May 17, 2017Aspirant
WNR2000 apparently is no longer supported as it was not in the download center
michaelkenward
May 17, 2017Guru - Experienced User
HSBratt wrote:WNR2000 apparently is no longer supported as it was not in the download center
The support pages for that are here:
>>> WNR2000v1 | Product | Support | NETGEAR <<<
That is for V1. It does date back to February 2009, so it is pretty ancient. It almost certainly predates support for IPv6.
- HSBrattMay 17, 2017Aspirant
- sktn77aMay 17, 2017Virtuoso
v1 and v2 versions of the WNR2000 don't support the netgear genie interface firmware upgrade. Any current version of their routers will have this as standard but if you get an older one on ebay or craigslist, it may not.
- michaelkenwardMay 17, 2017Guru - Experienced User
HSBratt wrote:Ok I am upgrading to a Netgear 750.
That's not a model number either, just a wifi speed measure.
But you can use the products pages to match your requirements against the stuff that you can buy, if you decide to go with Netgear.
