HSBratt
May 12, 2017Aspirant
NetGear Genie Firmware Update and IPV6
While attempting to update the firmware on myGenie A3, I get an error message that the router is no longer supported or not found. Is the A3 no longer supported?
- May 17, 2017
Ok I am upgrading to a Netgear 750. Thanks for your input.
HSBratt
May 17, 2017Aspirant
sktn77a
May 17, 2017Virtuoso
v1 and v2 versions of the WNR2000 don't support the netgear genie interface firmware upgrade. Any current version of their routers will have this as standard but if you get an older one on ebay or craigslist, it may not.
