sirlancelot33
Dec 21, 2017Tutor
Parental control not working
Downloaded Netgear Genie. Router is on and running (using it now), but when I try to eneble Parental Controls in Genie, it tells me "Internet is not available. Connect your router to the Internet."...
- May 01, 2018
Hi db4545,
Welcome to the community!
1. What is the firmware version of the router?
2. Please try using another device (Android, iOS, computer).
3. Have you tried resetting the router?
4. Are you able to login through https://netgear.opendns.com/sign_in.php?
Dexter
Community Team
DexterJB
Dec 26, 2017NETGEAR Moderator
Hi sirlancelot33,
2. Please try using another device (computer, Android, iOS).
Dexter
Community Team
DexterJB
Dec 27, 2017NETGEAR Moderator
Hi sirlancelot33,
I have sent you a message. Please check your inbox.
Dexter
Community Team
- db4545Apr 27, 2018Aspirant
Was there a solution? I'm having the same problem. Opening Parental Controls through the Genie program on Windows does not work. It either says I'm not connected to the internet (when I am), or the OpenDNS login fails (it's an existing account I have verified in my browser).
R6700v3
- DexterJBMay 01, 2018NETGEAR Moderator
Hi db4545,
Dexter
Community Team
