Drtyone
Sep 16, 2017Follower
R7800 remote access with genie
How do I get the remote access to work when I am not on same network. I have he genie on iPad and it works just fine locally but does not show up when off network
- Sep 18, 2017
Hi all,
You can check the link below for the steps on how to setup the Remote Login feature of the NETGEAR Genie app.
http://kb.netgear.com/app/answers/detail/a_id/26109
Dexter
Community Team
michaelkenward
Sep 17, 2017Guru - Experienced User
With the Android app you have to create a NETGEAR account. There is an explanation of this in the manual, which should be at the end of this link:
genie Landing Page | Apps | Discover | Home | NETGEAR
Check page 7.
This probably applies also to the iVersion.
monsoon_qld
Sep 17, 2017Tutor
Yep I have. All my devices are listed. I have had RA working on it before, had a little difficultly with it a firmware update or so ago but this time it’s being much more stubborn. Just have to wait for another firmware update or Genie update. Will have a go at any other ideas that pop into my head in the meantime.
