Drtyone
Sep 16, 2017Follower
R7800 remote access with genie
How do I get the remote access to work when I am not on same network. I have he genie on iPad and it works just fine locally but does not show up when off network
- Sep 18, 2017
Hi all,
You can check the link below for the steps on how to setup the Remote Login feature of the NETGEAR Genie app.
http://kb.netgear.com/app/answers/detail/a_id/26109
Dexter
Community Team
DexterJB
Sep 18, 2017NETGEAR Moderator
Hi all,
Dexter
Community Team
monsoon_qld
Sep 18, 2017Tutor
Admittedly haven’t done that. Uninstall Genie from PC as I’m a bit of a minimalist. I use Genie on iOS and access/setup D7800 via 192.168.1.1 I’ll give it a go but I haven’t had any issues with R9000 at home and no Genie on PC. D7800 is registered to myNetgear account.
