Bhgrimes's avatar
Bhgrimes
Follower
Feb 01, 2023
Router wndr4300v2
My router is old but it’s solid. Today it started connecting then it would disconnect and all the lights would be solid Amber for a short time then it would connect for a short period of time and repeat the process. It’s done this all day. Is it a firmware update or is my router shot? Please help.
1 Reply
  • michaelkenward's avatar
    michaelkenward
    Connecting and disconnecting from what? The Internet? The modem? The Wi-Fi?
    Which LEDs? What does the power LED look like?
    There hasn't been a firmware update in four years.
    What firmware version do you have on the device?
    A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
    It might also help if you told people what the modem is in front of this router, if there is one. The make and model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
    The reason for asking is that a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
    This device is decidedly EOS.
    NETGEAR End of Service | NETGEAR
    You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
    SMART Wi-Fi, General and Legacy Routers - NETGEAR Communities
    You might like to search there for messages related to your problem.
    I will ask the Netgear moderator to move your message.
    In the meantime you could visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
    Check for various troubleshooting tips.
    You may have done this already. I can't tell from your message.
    I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
