BobWillardsen's avatar
Feb 15, 2017
Access Point
Hello,   I'm having some trouble and could use help.  I have a device that does not have wireless capability but I want to put it on my wireless network.  I have the D6400 router.  I set it up as a ...
  • michaelkenward's avatar
    michaelkenward
    Feb 20, 2017
    If the TV is connected to the D6400 you don't need wifi to get the TV to talk to the CenturyLink router.
    Plug the router intro the D6400 and it will get its Internet that way.
    If the D6400 isn't connected to the router, tackle that first. I assume that the D6400 is the modem that gets you the Internet.
    What is the CenturyLink router doing? The D6400 also delivers wifi.
    Maybe you could explain the layout of your network.
