yawarmurtaza's avatar
yawarmurtaza
Add 3rd adapter to an existing PowerLINE 1000 + WiFi network.
Hello,    I have successfully installed PowerLINE 1000 + WiFi https://www.netgear.com/home/products/networking/powerline/PLW1000.aspx#tab-techspecs and everything is working as expected which is go...
  • michaelkenward's avatar
    Oct 27, 2017
    yawarmurtaza wrote:
    I have a need for wired network in another room and I dont know which PRODUCT i should buy that will join existing power line network.
    Most recent Powerline devices follow the AV standard, which means that you can mix different makes and different generations. The only issue if that if you add "AV1000" plugs to a network with "AV500" plugs they will talk to each other at the speed of the slowest plugs on the network.
    When you do add plugs to an existing network, you should follow these instructions:
    Powerline Networking | Powerline Ethernet | NETGEAR
    Remember, you need only one "source" plug connected to the router.
    One other thing to consider, in theory you can mix brands but it isn't always easy to get set them up.
    yawarmurtaza wrote:
    I am not looking to buy a pair, just 1 adapter that will join existing network.
    Most suppliers of Powerline devices, including Netgear, sell pairs. You may find it hard to buy a single plug.
