Murphys110's avatar
Murphys110
Add-on to existing PowerLine 1000?
I have the access point and adapter and would like to add an additional adapter in the house but only want that one to have an ethernet output (no additional wi-fi).... does that exist as a product to purchase?
Many thanks for any direction.
  • michaelkenward's avatar
    michaelkenward
    None of the major powerline makers seems to sell single plugs, wifi or otherwise.
    You may be able to find a second hand one, or something from a different maker. In theory different makes are compatible because they follow the AV standard. Getting them to work together may be a different matter.
    You could buy a powerline pair and find another use for the extra plug.
    • Murphys110's avatar
      Murphys110
      Thanks. It's too bad... but I guess there's not much demand for one-offs... even though it's pretty inconvenient to have to buy two and basically waste one.
        michaelkenward
        Perhaps there is a market out there for singletons.
        Or use it for something that would be better wired, like a smart TV.
