stevo1_l
Oct 17, 2016Aspirant
Adding an additional PLP1200
Hello, I use a pair of PLP1200 powerline adpaters to provide a decent connection to an upper bedroom. If I purchase a singular unit for another room can I connect it from the existing one which i...
- Oct 19, 2016
Thanks for the replies all. My additional PLP1200 arrived last night, and after performing a reset on it has synced with my other PLP's. All working as expected.
CheersSteve
michaelkenward
Oct 19, 2016Guru - Experienced User
stevo1_l wrote:That's great, thank you for the reply. I have sourced a singular unit (2nd hand) ..
Remember, the network will operate at the speed of the slowest plug. If the second hand one is really old, it is not likely to be as fast as the 1200s.
It may not matter. But you have been warned.
stevo1_l
Oct 19, 2016Aspirant
Cheers
Steve
